Hello all, I am in the process of relocating my pool pump/electrical/irrigation and decided to add some deck jets since the kool deck has been removed.
After going back and forth I decided to use Hayward jets vs. that of Pentair due to the height adjustment capabilities.
Where the discrepancy comes in is in the plumbing installation.
Pentair/Jandy recommends installing a manifold loop feeding individual runs to each jet.
Hayward explicitly states the opposite and recommends a system loop with branches to each jet.
My question to you is which system have you had good luck with, and for those that did a loop was each jet uniformed?
I do not care about adjusting each jet if they uniform to begin with.
Also, if plumbed in from a 3-way valve connected to the returns, is it redundant to have another 2 way valve for "Flow Control" as illustrated in the Hayward diagram. Would the initial 3 way be suffice for control?
Thanks in advance!
Thanks in advance!
