I’m currently torn between having a 16x32 pool with the spa integrated into the pool or a 15x30 pool with the spa outside the pool with spillover.
For the integrated option, the spa would be in the shallow end next to the tanning shelf. It would be half tanning shelf half 6x6 spa (with 1ft coping in between), stairs in front of tanning shelf (perhaps with 2nd stair spanning all the way across, in front of spa as a long bench). This option could either be flush or elevated with spillover.
The second option would be to have the spa outside of the pool over the deep end, raised 18’ with a spillover feature. This would allot the tanning shelf in shallow end to go all the way across, but have the stairs on the side of shelf vs in front. We could also do a larger spa in this case (maybe 8x8).
The total square footage of both options is roughly the same. (16x32=512sqft, 15x30 + 8x8=515sqft).
Anyone have thoughts on what would be better. I realize it’s a personal preference, but wondering if there are any considerations I should be thinking of. I assume the equipment would be same either way. Maybe a little more material, tile, coping needed for option with spa external? Thanks!
