Hello,
After recently completing my first SLAM I have begun daily testing for the first time using the TFP protocol. On the first day I ran all the tests and here were the results:
FC - above 5
pH - high, the test kit only goes up to 8.2
CH - 450 - on the money
TA - 90 - goal for my pool was 70
I entered the pH and TA numbers into the Pool Math app and it had me add 9.4 oz of the 31.45% - 20% Baume Muriatic Acid, which I'm pretty sure mine is, attaching a photo to confirm. Since then, I've been daily testing and adding liquid chlorine based on my FC readings (which are really hard to differentiate for me using the pH/FC daily testing dual tower test kit but I think I'm getting it). The pH reading has remained high every day but I haven't been putting anything in for the TA reading, assuming that it had gone done after the 9.4 oz on day 1. When I put 8.2 into the app it's only telling me to put in like 1.1 oz of the 31.45/20 Muriatic Acid.
Any feedback on my process? Am I doing anything wrong?
Thank you!
FC - above 5
Thank you!
