- May 22, 2021
- 195
- Plaster
- CircuPool RJ-60 Plus
Hi- got some Isocyanuric acid for free as part of ordering pool chemicals and wanted to see if this was the same as cyanuric acid- well it's not.
I don't want to divert form straight CYA- opinions?
From Chat GPT
Cyanuric acid and isocyanuric acid are both compounds that contain a triazine ring structure, but they have different chemical properties and uses.
Cyanuric acid (CYA) is a white, crystalline powder that is commonly used in outdoor swimming pools as a stabilizer for chlorine. It helps to slow down the degradation of chlorine due to sunlight, which can reduce the effectiveness of the chlorine in killing bacteria and algae in the pool water. CYA is also used in the production of plastics, dyes, and other industrial products.
Isocyanuric acid (ICA) is a derivative of cyanuric acid that contains a chlorine atom attached to one of the triazine rings. It is used as a disinfectant and sanitizer in swimming pools, spas, and other water treatment applications. ICA releases chlorine slowly over time, which helps to maintain a consistent level of chlorine in the water and reduces the need for frequent additions of chlorine. ICA is also used as a precursor for the synthesis of various chemicals and polymers.
In summary, while both cyanuric acid and isocyanuric acid share a similar chemical structure, their specific chemical properties and uses differ significantly. Cyanuric acid is primarily used as a stabilizer for chlorine in outdoor swimming pools and in industrial applications, while isocyanuric acid is used as a disinfectant and sanitizer in swimming pools, spas, and other water treatment applications, as well as in the production of chemicals and polymers.
From Chat GPT
