Hey all, we’re looking to cut into the slope of a big hill by our home for a large AGP (18FT x 33FT). Never done a slope before, hoping to run my plans by the group and see if anyone with experience can identify anything I might be missing, or any gotchas. I think the slope is about a 3-1 or maybe a 4-1 pitch at most. We live on a hilly, rocky area of Tennessee.
I’m hiring an excavator to dig down to undisturbed soil (mostly clay) a few feet wider than the pool in all directions, and create a “retaining” wall to support the raw exposed earth that was once the high point of the slope. I put retaining wall in quotes because the retaining wall will be a 45-degree pitch of packed dirt, probably 4FT tall so not too crazy. Below is a picture that sort of represents what this would look like. I think it will do fine. The brown area is the dirt retaining wall.
Going to create a berm to divert water on the upper slope before it gets to the retaining wall, and then a french drain around the pool for any water that makes it near. The berm will be as close to the wall as possible as to eliminate as much water from landing behind it and trickling down the slope. But some will get by, which is what the french drain around the pool is for. The pool will also have a deck around it that will cover most of the gap between the wall and pool, so water landing behind the wall and running toward the pool should be limited to whatever seeps through the decking.
Any guidance would be most appreciated!
