The pool service opened our pool yesterday, it's two years old gunite in New Hampshire, 39,000 gallon, UV/Ozone Chlorine system....cold and rainy, great timing ehh? The guys doing the opening said this was easy, chemically not far off, it looked really clean inside. They hooked everything back up, brushed the entire inside, all looks perfect. They also added half gallon muriatic acid, did a shock, and added something abbreviated as "accmo", not sure what that is.....alkalinity adjustment? I wasn't watching this.
Initial numbers they recorded for me before they added anything, ph 8+, alkalinity 70, chlorine 1.0, calcium hardness 300. I retested myself today as followup, ph 8.2+ (way off my scale), alkalinity now 100 (so maybe they did this adjustment), chlorine 5+ (makes sense with shock), calcium hardness 300. Water temp is 51F.
They hooked up the Polaris before they left....within an hour we looked in the pool, Polaris is on its side. Pulled it out, the bag was full of crystals....crystals so heavy the Polaris can't work. In fact, since yesterday we can only run the Polaris about 30minute before it fills up with crystals and is just dead in the water from heavy weight, we empty the bag and start again.....we've collected literally gallons of crystals in 24 hours. We've never seen this.....
I did a search on this forum, found a similar post from years ago.... Sediment/Crystals on pool bottom here are some pictures of our crystals. I'm thinking this unusually high ph is related somehow to what's going on, the water pulling calcium somehow from the plaster walls. At this point I'll continue to try to vacuum out the crystals while bringing down the ph. Any ideas out there on other actions?
One last point.....we found this article, seems to indicate these are calcite crystals, though I'm not sure what to do to deal with them? We did have a mesh cover over the pool for winter by the way. Calcium Crystals vs. Scale
