Hi,
I have a spot that comes up out of the ground as copper and then converts over to PVC. Yesterday I pulled it apart put pipe dope only on it and turned it on. There were no immediate leaks but by the morning it was leaking again period
I normally don't heat my pool but for Memorial Day have had the heat cranked for a couple of days so I don't know if the heat is causing an extra issue that hasn't been a problem in the past period
I'm planning to redo it tomorrow but was curious if I should put some Teflon tape then piped up and then tighten everything up.
Thanks
Rich
Thanks
Rich
