Hi, the corners of our pool have been sagging slightly more since we bought the house 2.5 years ago. The straight portions are fine, and it's obvious that someone did something to try to correct the corners. I've been told that when we're ready, we will need the concrete cut back 12" to remove all the coping/liner and install new. One quote I got to do all that was for about 25k. Is that in the ballpark you'd expect? Any other solutions you know of? We're in Maryville,TN.
Also, after pressure washing the concrete, a good bit of the top layer came off with it. At first I thought it was just paint, but it took more than just paint off. Is there any real resurfacing this, or is it a lost cause? Anyone heard of a residential rubber surface you can apply on top of concrete like in some commercial spaces? In one area by the diving board the rebar is peeking through.
We're really kind of paralyzed because the deck needs to be addressed- no body wants to walk on crumbling concrete this summer- but we don't want to waste money by doing any fixing to the deck only to tear it up to replace coping
Thanks for your thoughts.
