My 14x7', 2,500 gallon, 3' deep Endless Pool circulation pump recently gave out. In the few years I've had it, it never seemed to be sufficient to keep the pool clean in an outdoor environment in SE Michigan. The only mechanical part to clean it is/are 2 small donut filters that the water passes thru after it goes thru the skimmer...then the pump...then the heater...then the UV light...and back into the pool. No real filter. The guts are more like a hot tub than a pool.
I'm fed up with this set up so I am exploring getting a traditional AG pump and filter to fit in the same position in the "flow" as the circulation pump sits today (pic below w/ pump area circled). I'll have to retrofit (cut PVC pipes, add adapters for the flexible hose, etc.). I don't think that will be an issue. I went to a local Water Works and they suggested this AquaPro 100 sq ft Cartridge System, saying this is the smallest they have. It costs $630, replacement filters are a whopping $150, money's tight, and it seems like overkill for my sized pool...but the overall concept is what I'm looking for. (To elaborate, I don't want to have to rely on the spa electrical panel to plug in the various parts bc when it too dies, it'll be expensive to replace and I don't really use it. I don't even need the heater bc the sun warms it up fast. I just want to plug into a normal electrical socket and have the water cleaned effectively and efficiently like a regular pool.)
Issues/Questions
1) I can't find anything on AquaPro, it seems like an unknown. Not sure if I can trust it. (A quick search in this forum didn't reveal much.)
2) I feel like I'm hitting a nail with a sledgehammer. My neighbor has a similar setup/equipment and his pool is 10,000 gallons. I feel like I probably could save a lot of $ if I bought a combo or standalone filter/pump more aligned with my pool's size, even if it's for 5,000 gallons.
3) Is there a risk that a pump of this size is too powerful for my pool/spa components?
4) In short, can I likely do better than this AquaPro--better price, better sized HP for my pool size, better quality brand, more affordable replacement filters, etc.? Preferred budget for both filter and pump=$500; prefer replacement filters to be $70-$100. I am okay with buying them standalone but Water Works said it's more economical to buy as a combo unit...(?) EDIT: reading the Pool School articles made me realize that the larger filter size offers me something I really like: less cleaning required. Drives me crazy to always be cleaning the little donut filters. So maybe bigger IS better in my case.
Any other insights are appreciated as well. Thank you!
Lisa
Issues/Questions
Lisa
