Container pool questions
ebuckeye
1
ohio
Hello.
I recently purchased a small (16x8x5) container pool and I have a few questions.
1. What type of liner is better the inside to seal it? Maybe a roll on or spry on sealant m?
2. It has two windows/clear panels on the side. One is 4x8 and one is 4x7. Is 1 inch thick plexiglass tuck enough to support the pressure and also what is the best way to install these panels?
3. Any advice on pumps, returns, heaters, etc on a pool of this type ?
4. What does everybody recommend for a cover for it?
Any advice would be appreciated.
Thank you in advance!
Todd in Ohio
Welcome to TFP from Ohio!!!
There have been few container pools discussed on TFP...very few...(see below). Is this a MODPOOL?
I think the one I remembered, and posted below, used an epoxy paint.
ModPool uses 1” thick acrylic. (https://modpools.zendesk.com/hc/en-us/articles/360052373253-What-Are-the-Windows-Made-Of)
Same advice as a regular pool.
I'd use a solar cover.
Other container pool threads:
