Most likely, you will need 3/4" size.
Specification
3/4" Trade UL Type LFNC-B Liquid Tight Flexible Non-Metallic Conduit PVC Jacket
Applications:
• 3/8″ through 2″ rated for direct burial and poured concrete
• Hazardous locations where Flexible Connections are required per NEC 501.10(B)(2)(4), 502.10(A)(2)(3), 502.10(B)(1)(1), 502.10(B)(2), 503.10(A)(3)(3), 503.10(B), 504.20
• Industrial and commercial applications
• Indoor or outdoor locations
• Suitable for pool and spa use
• Air conditioning and HVAC units
Also Known As:
Type UL, Type LFNC-B, Liquid Tight Conduit, Flexible Conduit, Non-Metallic Jacket, PVC Jacket, 6003-30-00 AFC, 6003-46-00 AFC.
Description:
• UL Listed
• Rugged Non-Metallic PVC
• Interior integral reinforced member within conduit wall
• Integral Type B construction per NEC 356.2(2)
• Outdoor applications including direct burial
• Rigid PVC spiral core for strength
• Rated for concrete embedment
• Sunlight and oil resistant
• Non-conductive raceway
Specification:
• Trade Size: 3/4" inch
• Coil Length: 100ft
• Reel Length: 700ft
Weight: 0.1890 lbs/ft
• Internal Diameter Min: 0.820 inch
• Internal Diameter Max: 0.840 inch
• External Diameter Min: 1.030 inch
• External Diameter Max: 1.050 inch
• Bend Radius: 4.25 inch
• Part Number: 6003-30-00
• Part Number: 6003-46-00
Also Known As: Type UL, Type LFNC-B, Liquid Tight Conduit, Flexible Conduit, Non-Metallic Jacket, PVC Jacket, 6003-30-00 AFC, 6003-46-00 AFC. Description: • UL Listed • Rugged Non-Metallic PVC • Interior integral reinforced member within conduit wall • Integral Type B construction per NEC®...
nassaunationalcable.com
