Concrete blocks/pavers under sand filter and pump?
joshl
24
Wisconsin
I'm looking to add concrete blocks or pavers under my sand filter and pump this upcoming summer. As seen in the photo below, the area is kind of a lower wet spot, and the filter seems to be sinking in the ground a bit. The grass trimming around the area is kind of a pain as well.
I'm not seeing a lot of guidance or "how-to" information online about this. Any reason why this shouldn't be done? I'd still make sure the ground wiring gets to the pump.
Also, any recommendations for block or paver type? I would just do a 3'x3' section at the most, to again avoid having to trim right up against the filter/pump.
Any help would be appreciated...as I'm not much of a DIY guy. Thanks!!!
(the pump's not shown in the photo, but it lays just to the right of the filter on the black platform)
You can buy lightweight concrete or plastic equipment pads for pool equipment. They're larger than paver. I would be concerned pavers could individually sink into the ground over time, especially ones under a pump due to the vibration from the pump. Here are some examples.
Pool Supply Unlimited | Equipment Pads
+1. I had a preformed pad and it was falling apart in 5 years. I can't say if it was the heat or the cold because we get a few weeks of both.
They are $130 ish at the pool store and that will more than cover a couple bags of gravel and sakrete.
Reactions: wireform and JamesW
