Concrete and concrete stamped release stuck/stained Fiberglass Pool
Kkeebler7
4
Raleigh, NC
I recently had my pool deck installed with a stamped colored concrete border around the pool and then brushed concrete for the pool deck. So the stamped powder release they use to darken the stamped concrete has stained the perimeter of my fiberglass pool around the top of the walls (almost like a ring around the water line). Has this happened to anyone else or anyone have any ideas on how to fix this? Some sort of pool cleaner that helps or something non-abrasive that won’t affect the gel-coat, but will remove the stains? Thanks!
I will definitely try the magic eraser. Yea some of the stains are dried film of the concrete where other marks are droplets of the concrete that is now adhesive to the fiberglass. Any tool or mechanism that could be used as a scrubbrush/scraper to release these hardened spots without affecting the integrity of the gel coat?
Concrete will dissolve with acid. Try diluting some muriatic acid to 5 or 6 to 1 with water and spraying or sponging that on the concrete.
Be sure to wear eye protection when using acid.
I will definitely try the magic eraser. Yea some of the stains are dried film of the concrete where other marks are droplets of the concrete that is now adhesive to the femara for fertility. Any tool or mechanism that could be used as a scrubbrush/scraper to release these hardened spots without affecting the integrity of the gel coat?
can you update? really interested in the results.
We have used a magic eraser to clean the grime and pampered chef scraper to remove what was still adhered.
and the result? is it really "magic" or we should opt for something else? thanks
