My very first year with a pool. Sand filter. 26,xxx gallons. Pool was very green when we took cover off. Since then I bought a Taylor test kit to get dialed in. Initially, before the kit arrived I dumped 8 gallons of liquid chlorine shock which made the pool turn to a cloudy blue. Very low visibility. Sand filter running 24/7. Brushed the side and bottom. Ran the Polaris pool cleaner lots. Vacuumed the bottom. I would say there is no debris in the pool now.
After testing I initially found my CYA to be really high at 180. I partial drained and refilled with city water and found a new CYA of 100.
I am trying to achieve the SLAM process so I Started with 5 gallons of liquid bleach. Then 8 gallons the next day. Now I have a WHITE FOAM covering my pool surface. I checked the sand filter with DE and there were no leaks and I haven't found any leaks elsewhere so far.
My test results after that:
FC 15ppm
CC 1.0
PH 7.9
Alk 275
CH 250
CYA 60.
Yes 60 somehow with no rain or new water. Maybe the fresh water wasn't completely mixed when I tested at 100?
I read some more on here and decided I needed to use Muriatic acid because the high Alkilinity may be causing the foam. I put in 1 gallon last night after work at 9pm.
todays readings at 4:45 AM:
FC 10.8
CC 0.8
PH 7.4
Alk 230
CYA 60
Still the white foam on the entire surface and the water is cloudy blue. I'm at work today but had my wife put in another 2 gallons of bleach around noon today to keep the chlorine up. I hope I've given enough chance for chemicals to mix here. My son got 8 more gallons of chlorine and 4 gallons of Muriotic acid. I would love some advice on how to approach this from here. thank you
FC 15ppm
CC 1.0
PH 7.9
Alk 275
CH 250
CYA 60.
FC 10.8
CC 0.8
PH 7.4
Alk 230
CYA 60
