I'm a relatively new tub owner and have learned a lot of information thanks to the knowledgeable people on this forum, but I have searched and haven't found any definitive answers to the issue I'm having. The problem is that when the pumps have been off for a while the water looks clear, but after they run, the water turns a cloudy/milky white with little white particles floating around. I don't think they're bubbles because when I rinsed the filter yesterday and then put it back in the filter area, the water that was displaced as I was dropping in the filter came up was milky white, like the particles are heavier than water and settle down into the plumbing. And that's why I figure it happens when the jets come on, that they settle to the bottom and then get stirred up when the water is in motion.
My tub is a small Lifesmart LS100 200 gallon tub. I'm using the bromine Frog Serene system with the blue mineral cartridge and the yellow bromine cartridge. I know I should invest in a higher quality test kit like the Taylor ones, but since I'm not sure if bromine is the source of the problem I'm having I'm using the Frog test strips and a Poolmaster basic drop kit that does Ph and TA. The Poolmaster kit I think only does residual bromine and not free so I use the strips for free bromine. I also added 50ppm of borates through boric acid.
My current numbers from the combo of the strips and drop kit are:
Free bromine 10+
TA: 50
ph: 7.6
TH: 150
Bromine is high because I recently shocked with a 1/4 cup of bleach to try and clear up the cloudiness as that seemed to work for some other posters. My fill water is only two weeks old and I used a hose filter for metals. It doesn't look like the chlorine shock fixed it for me though, the water is still milky when jets are on. I have photos attached with the still water, pump on and no aeration, and then with aeration.
One thing I do wonder is if it could be undissolved particles of the bromine tablets? I bought bromine tabs of the same chemical composition as what comes in the Frog yellow cartridge and I took the top off that and put the tabs in there, and I noticed that the feeder hole on the yellow cartridge has become discolored white as the bromine has been exiting the little holes. Could that be what's causing the milkiness?
Any ideas as what the cause of this cloudiness could be and how to fix it would be great. This is my second fill of the tub and by the end of the second month on the first fill the water was super milky and while it felt fine to use, my wife didn't want to get in and it does take some enjoyment out when the water isn't clear. And it looks like the second fill is already starting to get milky again after only a couple weeks.
Free bromine 10+
TA: 50
ph: 7.6
TH: 150
