We have an Illusion 40’ Fiberglass pool from Imagine Pools just installed this Fall. Didn’t get to use it yet, but done just in time for closing. We have an Integra Autocover as well. I’m seeing mixed opinions all over the place.
My main questions are:
1) should we drop the water level? Our tanning ledge in our shell has bubblers. Dropping water below the jets isn’t quite far enough to drop it below the bubblers, so curious if we should drain to just below the ledge and then plug everything?
2) we have an autocover. The general consensus seems to be you don’t want to use that if the water level is drained. Our installer told us we could use that as the winter cover but I’m skeptical about that, especially if the water level is lowered some.
My PB advises the above steps for closing. I’m just not sure I agree. Given it’s FG, I’d feel better leaving the water level up after blowing out lines (or refilling after putting plugs in, either way), using a gizzmo skimmer plug, and then either using autocover (since it’ll be sitting level on the water where you want it) or opting for a safety cover. Less concerned with that, but really not a fan of dropping water (1) and (2) then using auto cover on lowered water.
Lastly - we live in STL metro. Any advice would be greatly appreciated.
