I haven't posted in a while because my pool has been trouble free!! This season opened up late April to a beautiful, sparkling pool. It's been rainy and a terrible spring here in Chicago. My pool has been blue, but had a few bouts of looking like it may go south so I started SLAM. My problem is my pool is sparkly, passes all 3 SLAM criteria, but has a musty smell to it. I'm assuming the algae is just being barely kept at bay? Here's a recent test result, kit in signature:
Water temp 76 degrees
FC 6.2
CC 0
pH 7.4
TA 80
CH 240
CYA 20 (I added 4 lbs earlier this spring, I also use the Pentair Rainbow CYA test kit so I'm pretty confident in my results, also no leak I've only added a small amount of water 1 time since opening)
Thoughts? I know FC is high for CYA but I'm trying to keep it up since there's this musty smell. Do I just need to keep at SLAM level for like 2-3 days after I pass all 3 criteria???
My pump runs 24/7 and IC 20 (I know, undersized but it's what PB installed) running at 100%.
FC 6.2
CC 0
pH 7.4
TA 80
CH 240
