I opened my pool the week end before Memorial day. Water was crystal clear. Added 6 lbs cyanuric acid which brought me to 40PPM. Brought the PH to 7.6PPM from 7.2PPM, total alkalinity to 100PPM from 60PPM, calcium hardness to 240PPM from 180PPM, free chlorine to 3.5PPM from 0. Checked the water for 5 days straight. Everything was fine aside of adding a little chlorine. Put the solar cover on the Friday before Memorial day. It has been on since then. 3 years ago and the 2 years prior was a nightmare with chlorine lock. Took 12 to 16 gallons of 12.5% to get rid of it. Just went out to test the water and it is completely expletative out of wack. Chlorine is non existant an hour after dumping 2 gallons of 12.5%. Normally 42oz brings it up a little less than 1PPM, PH went from 7.6 down to below 7.0. Cyanuric acid is down to 10PPM from 40PPM. 5 days ago everything was fine! The only thing that is ok is the total alkalinity 100PPM. I'm demoralized. The weather the last 4 days has been way below normal temp wise and cloudy damp. There is a lot of pollen on the solar cover. Is it possible the solar cover is causing this? How is this possible?
