So I am new to operating the pool and plan on doing all of the testing on my own once I get my feet under me for operating and testing. I have the TF test kit but have not had the time yet to fully read all of the instructions and use the kit (life has been pretty crazy). I do have some AquaCheck 7 strips I have been using to get me by and we took a sample to the pool store today as a check; in general what they said about the chemistry was in line with the test strips but I had a few quick questions about the information. Pool is a vinyl liner pool; started it up with floating chlorine pucks but planning on converting it to SWG very shortly so purchased a few gallons of 10% bleach to adjust chlorine as needed until the SWG is up and running in a few weeks:
1. Since I did not install the pool I do not have the exact volume of the pool. I have taken some measurements and it is around 20,000 to maybe 25,000 gallons depending on how I run the numbers. Is it better tp pump the lower volume in the pool math app so you do not over add chemicals and then adjust as I start to learn the pool?
2. The chlorine was a little low so I added some bleach and overshot just a little but the free chlorine was still ok; I was not sure if this is because I had too much volume in the pool math or adding the liquid bleach is that sensitive.
3. The pH of the pool needs adjusted as it is high; they did not have any chemicals at the pool store and they suggested just using muriatic acid by diluting it in a five gallon bucket of water and then adding it to the pool in quarters of the total amount needed once every four hours. I know there is a difference between dry acid that the pool store sells and muriatic acid and was not sure if one was better or anything to be aware of with the vinyl liner pool.
4. The test said the phosphates were super high in the test 2,074 ppb; I cannot remember if the test strips looked at that or if it was how we took the sample into the store. Is it work buying a special chemical to treat for this or would it be best to just tackle the pH first and then retest to see if anything else needs addressed.
Thanks!!
Thanks!!
