I am in the process of changing the shaft seal on my 2011 Intelliflo 011018 pump. I purchased the Pentair go kit and have gotten things apart and started to do the clean up and reassembly when I noticed that the rubber seal in between the shaft seal and front bearing has a slight crack in it.
There is no water damage to the bearing and it feels smooth when I rotate the shaft but to be safe I would like to replace the rubber seal before reassembly.
The problem I have is that the rubber seal does not appear on the usual parts diagrams I have been able to access so I am at a dead end trying to locate one. I searched for Pentair VS-20 which is the number embossed on the rubber seal without success.
Does anyone have any suggestions to locate one or if I should even be worrying about the condition of my existing rubber seal?
I appropriated this pic from another thread related to shaft seal replacement to show the seal I am referring to:
