Change Tork Timer to Suraielec Smart Wi-Fi Box Timer Switch
evansjere
2
Carmichael, CA
Hi All,
I am trying to change timers from analog to wifi. Any help with the wiring would be appreciated.
I have 3 side by side Tork analog timers which turn on the Sweep, Light, and Filter and are arranged in that order in my box. I have purchased two wifi timers planning to change out the Sweep and Filter timers for now as my light is not working currently that is my next project.
Thanks for looking and for any possible help.
Jeremy
Welcome to TFP.
You said you have three timers but you posted pics of two.
You need to completely understand your current wiring from the CBs powering the circuits through the timers to the devices. It looks to me like the power is interconnected between the timers.
You need to identify what each of the wire bundles going into a timer box lead to. And don’t block viewing the wiring with your labels.
Much more details about your existing wiring is needed.
If you cant figure it out then get an electrician to do it.
Reactions: Jerz
Your wiring is old and more complicated and interconnected then you think. Get an electrician to sort it out.
A pool forum is not the right place to help you.
