CAT 2000 Issues
HouseWelder
In The Industry
Nov 15, 2023
2
Maryland
Hi, I'm new here but was hoping to get answers for an issue I am having with our indoor pool.
We have a Hayward Cat2000 ph/orp Automation Controller, and about a month ago we started to have a problem with the orp feeder.
The feeder itself (a Stenner 45MP2) works fine when plugged into the wall and turned on. the Ph feeder (we use co2) works fine as well.
The issue we are having is that the orp isnt feeing when plugged in to the cat2000, tested for voltage at the plug and even at the terminals were the wires for the plug go in. No power, we tried swapping the main power fuse with the orp one and saw no difference.
*Note all tests were performed when the orp was set to manual feed not auto, thus bypassing the set values.
Welcome to TFP.
Few people here use the Hayward Cat2000 ph/orp Automation Controller. Below is a link to prior threads on the CAT2000 that you may find helpful.
Currently we use a Hayward CAT 2000, but being we have so many issues not only with finding parts, but also with self servicing it. I was wondering what other controllers people have used in a commercial pool situation.
HW,
Most of us here at TFP have residential pools...
What all does your current automation actually automate? If we knew that, we could tell you if our automation systems might work for you.
Just found this article due to me installing that same pump on a cat 2000 system. Noticed a burning smell from the first stenner pump running, then went and looked, stenner pump rated for 1.7amps, old hayward pump it came with rated for .06 almost a 30x difference in amperage. I’m assuming the controller isn’t designed or wires or too small for this much amperage. I’m gonna go ahead and run just one pump off it for 24 hours too see what happens. So far this cat 2000 been garbage though. Pump works terribly, $350 flow switch bad after one year. I’m disappointed in it, and that’s why I bought stenner pumps to start upgrading things.
