Can't Find Photos of Glass Tile
w00dstock13
4
AZ
Hi all! We are in the thick of picking out tile - very overwhelming for someone (me) who is indecisive and not great at visualizing. We have narrowed it down to 3, but I can't find ANY photos of ANY of them installed... I have searched all 3 of them multiple times on here, Google, Facebook groups, and nothing!
Anyone able to help? One is from QDI (Islands Santorini), and the other 2 are from Noble Tile. I also know the "gun metal blue" one from Noble is actually the Artistry in Mosaics brand, but still can't find photos. Would appreciate photos if you used any of these or have seen photos! Thanks!
Hi and welcome to TFP!!
Two things to know about that can really change the colors:
-mortar-this will affect the color of the tiles. It come in white to dark gray. You can get some paint cards and put the outside in the area the pool will be. Put the tile on top of the paint cards and see which color you like the best.
-Grout-There is not wrong answer for this one. White will make each tile pop where gray will kind of help the tiles blend from one tile to the next. They should have some grout sticks for you to use to see what color you like then best.
I hope this helps a bit!
Welcome to the forum.
I see you are in Arizona. Be very aware that maintenance of a glass tile can be problematic with the scaling tendencies of your water. I would highly encourage using only softened water for make up water. You will still have to deal with some water line scale so be sure you understand the processes to clean any tile you install.
Yes! This is one of our main concerns. I'm planning to call around to some pool maintenance companies to get their opinions on what they see as far as wear and tear on glass tile around town. We do NOT have soft water at our house, so the calcium buildup is definitely a concern.
We are also considering just doing glass on our spa spillway and a coordinating (as much as we can) porcelain as our waterline.
Thanks for sending! I've seen this one on their website, but was hoping for some real life photos! The color also looks completely different in person than it does in this picture. It's not a great representation of the actual product, unfortunately.
Thank you! Great tips. In my short time here I've noticed you're the tile queen ;) This has been the hardest decision BY FAR!
Reactions: kimkats
