Posting pictures of the damaged area would definitely help, but if there is a large surface area that’s cracking and peeling then I suspect that it may not be repairable. If it’s just one or two small spots then a vinyl repair kit might take care of it.
I don't know what the sofpool is made out of. It seems to be a nylon fabric coated in a rubber like an EPDM roofing material. It's VERY thick and heavy. It reminds me of a small zodiac boat we had years ago. I found some repair kits on a boat website but they have different glues for different types of "fabric" polyurethane, PVC or hypalon. allinflatables dot com. There are a LOT Of rips and tears like in this photo. The water only goes to the top of the blue part. The white part doesn't hold air because there's an air bladder inside of it which forms the top ring of the pool. But water does splash and leak out of the tears. How about Flex Seal liquid rubber sealant coating? Thanks for your help!
