We are building a pool and a separate raised spa that will be located 5 feet from our pool. We had planned on 2 separate systems so we could use the spa all winter and heat both the pool and spa to different temperatures at the same time during the spring and fall. However, due to the extra space required for a second system, our pool builder suggested we use a shared system (gas heater).
He said we could winterize our pool in October/November and keep just our spa open all winter by putting it in spa mode. Is this true? Are there any problems with doing this? Will winterizing our pool and putting our heater in spa mode prevent all water from going into the pool pipes? I am concerned about freezing pipes. We will be getting a generator for our spa in case the power goes out in the winter.
Are there any other issues I should be aware of with using a shared system where the spa is separate from the pool (so no overflow)?
Also, in the spring/fall if I heat my spa to 100 degrees in spa mode and then switch to pool/spa mode will the temperature of my spa go down (does the cold pool water mix with the hot spa water in pool or pool/spa mode)? Is there any way I won’t have to heat my spa from 80 to 100 every time we want to use the spa. We will cover our pool with an autocover and our spa with a normal cover at night.
I assume I will need to keep our system in pool/spa mode at night to filter and circulate the pool and spa, so I will either have to heat both our pool and spa to 80 degrees through the night or not heat either at all during the night. Either way I assume it will drop my spa temperature a lot each night.
Do they make gas heaters/shared systems where you can heat the pool and spa to different temperatures at the same time?
Thank you in advance for any advice/answers you can give.
