This maybe a silly question, but can I use the pool pump to open up the pool this season? When I had a service, the techs brought their own pump and vacuumed the pool using that pump and the waste went directly to the street. This seems like a great idea to me because on opening, my pool floor is full of dirt and worms. So I definitely don't want to be running that through the filter. I know I can bypass the filter but I still have some doubts. First, the waste on my system goes to a separation tank before it goes to waste. I guess I can remove the net in there when I want a true waste option? Secondly, I get hundreds of worms and dirt and maybe sticks/leafs. Will it be save to use my normal vacuum for all of that? I am not sure its safe to have dead worms going through the pump and ducts.
Or should I bypass all of those questions and rent a separate pump similar to what the techs used? If so,, what pump should I use for this? I see some options on home depot, but I am not really sure what I need. Here are some options.
Wacker 1 in. Gas Water Pump Rental 5100013999 - The Home Depot
Rent a 1 in. Gas Water Pump Rental from one of our over 1,200 THD rental locations. Call your local store for same day pickup availability.
www.homedepot.com
