hi,
What I did this year for closing the inground pool was a little bit different than last year. Instead of screw the gizzmo in the skimmer pipe, I used the rubber plug to cap all the skimmer pipes from inside the skimmer after blowing out all the water inside the skimmer lines. Then simply place the gizzmo inside the skimmer and cover it with skimmer cover and put a heavy brick on top of the cover. (The gizzmo is long enough that it can only get out from the top.) I do think this will do the same thing as screw in the gizzmo. am I right? plus with the rubber plug on, I can make sure there is no water back into the skimmer line, so no need to pour in the anti freeze. (With the plastic gizzmo screwed in, I still can see the little bubble coming out when I blow out the air, which I think it is not as air tight as a rubber plug.)
Has any one have any experience on it? Should it be working? Any advices?
btw, is there any better way to check if a gizzmo cracking or not? (I think for anyone using gizzmo, a crack on the gizzmo would be a very dangerous thing.)
thank you.
thank you.
