Can I bypass the pool Control Panel and go directly to Pump
hayson337
1
P@$$word337
Moved from here... Pumps, Filters, and Plumbing
My Hayward Control Panel has gone "haywire" and I am no longer able to control my Pool Equipment via the Control Panel.
I would like to take the Power that is going into the Control Panel and wire it directly to the EcoStar variable speed pool pump.
I have attached some pic's. I have read up on wiring the EcoStar and the only questions I have are:
1) There are 4 wires (Red-pwr, Blk-pwr, Grn-ground, and a White-?? wire) The instructions only call for 3 wires and a ground wire (which is already connected to the side of the pump motor (solid copper).
2) The size of the wires coming off the 25 amp breaker are huge. I am not sure how easy it will be to wrap those thick wires around the pump terminals.
mose
Here is the video on wiring the pump. At the 4:39 spot into the video it talks about wiring the EcoStar Pump.
mose
I got the same problem. Did you ever get it bypassed?
Thanks
The Dude
337,
You might want to fix your location... :)
If you have a VS pump, you should be able to disconnect the control cable from the automation and run the pump as a standalone pump using the pump's control panel...
Tell us more about what you have..
