- Apr 18, 2017
- 86
- Vinyl
- CircuPool RJ-60 Plus
Hello, we have put an offer in (which was accepted) on a "new to us" house that has a very large inground pool. The current owner bought the house as a foreclosure a few years ago and therefor has no manuals, records, or anything really regarding the pool beyond her own maintenance when she took possession and she basically just hired a pool company to deal with it for her as she is not the "hands on" type.
I prefer to have a personal understanding of how things work and to maintain them myself (whenever I can) so I am doing a little advanced homework to learn what I can about the pool and the components.
I am not new to pools, I had a small above ground, salt-water pool for nearly 10 years, but this inground pool is a monster, and it is a little intimidating.
Here is what I know:
Beyond the obvious things (test the mechanics, coping, look for any obvious damage to liner, etc.) to be aware of, do you have suggestions for what else I should be concerned about, looking for, etc.?
Also, if you have any experience with this Jacuzzi filter or Jandy heater, please share your wisdom as I cannot find an owners manual online so I’m guessing they are fairly old.
Last, I will need to invest in a safety cover (dogs/kids) and I'm curious if a standard rectangle cover will work on a Gothic shape (it's basically a rectangle with inward curving corners) or if I will need to custom order one? Thoughts on that?
Kindly,
Stephanie
- Pool was put in sometime between 2000 and 2004 (there are aerial photographs of the subdivision that show no pool in 2000 then no photos until 2004 which then shows a pool)
- Pool is 25 x 45 with a diving board and slide. I don’t know how deep the deep end is, but I am told it is 55,000 gallons total.
- Pool has a liner (6 years old), and the shape is called Gothic (with 4’ radius curves).
- The steps or on the right side and there is an additional ladder on the deep end.
- The filter is a Jacuzzi Tri-Clops model TC-300
- It has a 399,000 BTU heater, brand is Jandy
Kindly,
Stephanie
