After 20 some years of public pool usage I decided to have my own pool so I purchased and installed an above ground endless pool 1400gl soft vinyl, outdoor installation. Trouble is, everytime I swim, within few ours, I feel chest compression and burning lungs lasting til the next day. The water was tested by Leslie(see attached) and it seems ok, I kept the chlorine level low. At one point I switched to bromine thinking that perhaps I have developed a chlorine sensitivity but no change In the lung problem. Did a pool shock one time. The only thing I have not tried is to swim in just fresh, untreated water to rule out sensitivity to chems, chloramines or vinyl fumes. I am at a loss on what it’s going on. The local pool technician has no advise, doctor says to use Albuterol(not a good solution for me). I am otherwise healthy and no virus present or previous asthma. The trigger is the swimming in the pool activity For sure.
Here is what I use to balance the water
-Pool chlorine at 12.5% 1/3 cup a day
-Ph down: Sodium Bisulfate 100% Spapure brand
-Ph up: sodium carbonate 100% Spapure brand
-Alkalinity increaser: sodium hydrogen carbonate 100% Spapure brand
Calcium: 100% calcium chloride even thou I understand it’s not required because of the vinyl.
Spapure chems came with the pool purchase. I keep the water temperature to 83F, covered most of the time. The manufacturer looked at the report attached and suggested to areate the pool prior to usage so the last couple of times I did open it up for 4-5 hours prior to usage. I’d like to say it made a difference but not really certain.
ANY help would be apreciated because at this point I feel like I am running out of options.
Thank you!
Thank you!
