On my Bullfrog spa, I'm able to schedule the filtration cycles of my WellSpring filtration pump, including setting for 24 hour filtration. The default setting was everyday 8am and 8pm for 2 hours. When I was having trouble with water quality and oxidized metals, I had set it for 24 hour for several days to clear the water, which it did. But I noticed that it didn't always appear to be running, or at least not very detectable. I guess I expected the filter baffle plate to open some. And sometimes if I want it to start ASAP, rather than at the next 1/2 hour interval, I "trick it" by changing the clock time. But I noticed that it doesn't appear to start when I think it should. Is this normal operation? Bullfrog seems to use the terms "filtration pump" and "circulation pump" interchangeably. I assume setting the filtration cycle is same as circulation? I ask this since many chemicals say to add them with the circulation pump running. The Bullfrog manual and website make only brief mentions of this pump.
Per the manual:
"If your spa uses a circulation pump configured to run 24 hours, the screen will show you the purge setting instead of filtration. The purges are pre-programmed for a fixed number of minutes, therefore the duration will be set to N/A on the screen, and only the start time can be modified."
How do I know if I have a circulation pump configured to run 24 hours? I don't see any purge setting, so I guess I don't.
Per the website:
"WellSpring™ Circulating Filtration Pump - Bullfrog Spas’ WellSpring Filtration Pump lets you filter your spa water without noise or high costs. This quiet and vibration-free circulation pump is more than 8 times as effective at filtering spa water than standard circulation pumps. The more times your water goes through the filter, the cleaner your water. Moving 35 gallons (130 liters) per minute, this pump can push every ounce of water through the dual filters many times per day." Hmmmm.... complete 434 gallon water turnover in 12 minutes?
Per the manual:
Per the website:
