I just got a new SWG cell and in the course of the install I had to remove PVC from the filter. For some reason the original plumbing put the cell under the filter, which has always been a pain, but a once a year pain on open. When I put it back together, there was a leak of the join at the filter where I pulled out to do the install. I went to tighten it and it cracked. It seems the only way to fix it is to cut the PVC and pull it off and replace a section. Is that correct? I am not going to do that myself, and if I have to pay for a fix, I will have them redo the PVC to not be under the filter!
