I had no idea broken glass in the swimming pool is potentially one of the biggest problems as a pool owner. This explains why I thought it was reasonable to try and perform chemical measurements using a glass bowl/measuring cup instead of non-glass.
Anyways, I've got a fair amount of broken glass in my pool now. I haven't started cleaning it up at all, and also just turned off the pump motor after letting it run for about six hours after the accident.
I've read these threads:
www.troublefreepool.com
How can I tell what damage I have done to my filter/pump/heat system? I have a sand filter tank, and a standard pump, and a natural gas heat exchanger. I see mentions of cartridges in other threads, and don't know if my system has any.
Is draining the pool fully really the only option? One forum poster above suggests the smaller bits of glass will be collected as sand if I vacuum up through the pump -- is that accurate?
A skimmer sock seems like a great idea, and will be leaving momentarily for one at a home improvement store about 30 minutes away. My idea is to use this on my vacuum hose and see how much I can into the skimmer sock.
Cleaning broken glass from the pool
Well, as the weather warms up here it north Texas, I feel I can avoid my issue no longer. A couple of months ago we had some windy weather that picked up a tempered glass-top patio table and slammed it into the pool deck. A good bit of the shattered glass then blew into the pool. Yes, I was...
Broken glass in pool
I, um, accidentally shattered a drinking glass right next to my pool, and some fragments went into the water. I already fished out all the visible fragments by hand. Now I'm just concerned about the micro fragments. Is it safe to vacuum the pool as normal? Do micro fragments of glass pose any...
