I have a rotomolded spa with bright yellow staining just above the waterline as can be seen in the picture. I tried Oxy (mixed with a little water to make a paste troweled on and let sit until hard then scrubbed off), boat hull cleaner, vinegar solution with a magic eraser (though I didn't wet the sponge, just sprayed the vinegar on and then rubbed with the magic eraser). Nothing has had any effect at all. Most of the advice I read is for acrylic hot tubs and I'm not sure it applies to rotomolded plastic. Has anyone had any experience with this sort of stain on a rotomolded tub and if so, did you find anything that would remove it.
