Brand new pool - small leak at bottom of Pentair Clean and Clear Filter
Zumbagirl
Active member
Jan 25, 2022
40
Lakewood Ranch, Fl
This equipment was just installed about 2 weeks ago. I've noticed when running, a ring of moisture on the concrete at the bottom of the filter. Upon touching the drain plug, I feel the drip along the bottom of the plug. Is this normal? I've contacted PB and sent picture with no response yet.
There's a o ring gasket in there. Try to snug it up a bit by hand to get some more pressure to it. If it doesn't help you'll need to drain filter and unscrew to inspect. Perhaps it got pinched which then it needs a new o ring or some debris not allowing it to seal. Clean and lube before closing it back up.
Thanks. How would you snug it up a bit by hand exactly? Sorry, not sure how it all works yet.
No harm done. It's just harder to turn while fighting the pressurized system. So you might not have tightened it as much as you could have.
