Bottom pad, wall foam and cove installation
If you have the sand/bottom level and set I WOULD put down the bottom pad at the very least to protect all of your work.. I would also put down the cove to keep water from going under the walls. The wall foam..........I would wait until right before you can put the liner on. I worry about the glue not drying fast enough to keep it up.
Kim:kim:
