Where is the bonding/grounding lug on a 1.5 HP Powerline XP I pump? The outside is all plastic. Electrician said to ask pool installer...pool installer said ask electrician. The copper wire is run but not yet connected to anything on the pump.
Some AG pumps don't have bonding lugs. Those double insulated pumps aren't required to be bonded, but on a new pool installation you need to run the bonding wire to the pump location for future use on a replacement pump.
