I have seen some talk on here about the 1.5 HP VS Blue Torrent, AKA Splash pool pumps.
I bought one ($400 on Amazon) and have had it running for about 3 weeks now and have not had any troubles with it.
I will say this right away- I do not recommend it for an inground pool. The reason is, all least my pump, I cannot get it to do a priming speed when it first starts up. Which isn't a big deal for me since the pump is below water level and I never lose prime.
With my SWCG I run the pump at 1500 rpm, which gives me right at 20 gpm. When I vacuum I increase the speed to 2500, which gives me around 35 gpm, and good suction for my vacuum. At full rpm (3450) the flow meter shows around 50 gpm. Right now I have is set to run from 10 am to 10 pm everyday at 1500 rpm, with my SWCG set at 40%, I might reduce the run time in the future, but for now it is working great!
Would I buy this pump again? For my application I would say yes. The big question is whether the Pentair 1.5 HP VS pump is worth the extra $200 to $250, you would need to decide that for yourself.
Hope this helps anyone looking to purchase this pump.
