Hi there.
I live on Long Island, NY. I have an round Intex 5,000 gallon Easy Set with an Intex 633T pump. I bought a Blue Torrent 32,000 BTU heat pump from Island Recreational. It's meant for a 5,000 gallon pool. I hooked it up and figured out the piping to make heat pump and the Intex pump connect with each other. When I finally turned on the heat pump, I get an "E3" message on the panel after about 30 seconds of turning it on, which is a ''water flow fault." My best guess is the Intex is not powerful enough. The specs on the heat pump says "Water Flow Volume: 14 - 24 GPM." The Intex pump says it can do 2,500 GPH which translates to 41 GPM. So I'm not really sure if the heat pump numbers translate directly. If anyone has any ideas, I would appreciate it!
