I installed a Hayward Aqua-Rite low salt generator in my pool in June of this year. Yesterday the “check cell” light was flashing so I took it out for inspection. The plates in the cell had quite a bit of light blue scale some of which was a good size. I should note that the previous Hayward SWG it replaced never had any scale buildup at all.
I tested the water today, the results are below. I add nothing to the pool except chlorine occasionally & muriatic acid.
FC- 4ppm
PH- 7.7ppm
TA- 80
CYA- 60
Calcium- 90ppm
Salt- 2100 ( a little high, recommended 1800ppm)
Does anyone have any idea what this might be or what caused it?
FC- 4ppm
PH- 7.7ppm
TA- 80
CYA- 60
Calcium- 90ppm
