I am new to this very comprehensive forum and will be diligently studying all of the material as I have learned my lesson about taking pool ownership / maintenance lightly. I have searched the internet and have not come across anything else like this issue. My water maintenance routine consists of keeping the chlorine level up and adding some acid now and then. So……………….a few days ago I purchased 4 gallons of chlorine at Home Depot and added it to the pool. As soon as the chlorine hit the water it began to cloud. It got extremely cloudy and then after a few hours blue flakes started forming and some falling out of suspension landing on the bottom. I let the filter run (de filter type) for a few hours, vacuumed and then decided to take the filter apart and clean it as it hadn’t been cleaned for awhile and could see that this was going to be a challenge for the filter. When I opened up the filter it was completely coated with a layer of bright medium blue “stuff”. It was as if someone took a spray can of blue paint and coated every inch of the diatomaceous earth in the filter. Before I added the chlorine I used a test strip and the water was very acidic. I had dumped in 2 gallons of acid and some chlorine a few weeks ago without testing. I am guessing that some kind of chemical reaction took place. I added 2 large boxes of baking soda which brought the ph into line and have been running the filter for two days. The water is clear now and has just a little blue sediment on the bottom which should be completely gone after one more vacuuming. The tile grout as does a little of the pebble tec coating has some blue staining.
Has anyone had this happen to them? What was formed? Anyway to remove or neutralize the blue staining?
