Hi, I'm a fairly new pool owner. Thought I knew what I was doing but couldn't figure out why my cya level kept going up. I thought my test strips were wrong so I bought a liquid testing kit and it agreed with the strips that I'm now over 100ppm cya. I only added cya at the beginning of the pool season to get around 40ppm so I did some research and found out somewhere along the way I missed that dichlor contains cya. Time to switch chlorine types! But now I need to drain half the pool to fix it. Is it as simple as attaching garden hoses to those two spigots on top of the pumps and closing the return valves from the skimmers? One pump is for the pool/spa and the other for waterfall. The drains are in the deep end for the pool and waterfall. Or should I be attaching a hose to that drain port on the cartridge filter? Only problem there is it looks like it's 3" diameter or more and the hoses I've seen are only 1.5" or 2".
Thanks for the help! Still can't believe I did this!
