For years, I have always added granular shock to my fiberglass white pool. Is it better to pre dissolve it?
Cal Hypo should be illegal to sell in Arizona.
Adding more calcium to our calcium rich fill water with the level of evaporation we have is not good.
Use liquid chlorine.
Thank you both for your advice. I hate the dry shock due to the fumes and trying to store it. I think I will go with liquid chlorine shock after my dry shock is gone!Cal-Hypo adds Calcium, which is not necessary in a FG pool. IN AZ, you likely have high CH in your fill water. Unless you have a heater, then you need about 200ppm. When calcium gets too high, you can get scaling, particularly if you have a tile line around your pool.
You should use liquid chlorine.
