Best bang for the buck 2 speed pump
Check with Inyopools to see what two speed motor will fit your pump.
Depending you may need a two speed timer also.
The two speed timer can switch the pool to low and high speed. In case you need high speed for a suction cleaner, or some other reason.
Some pumps struggle to prime on low speed, and thus it may need to start on high speed and then switch to low speed.
I have 2 pumps I can sell you, let me know
Great Pool pumps used less than 1 season Brand new July 2017 Buy both for $600.00 or each listed below.
1 Sta-Rite P6RA6E-205L Max-E-Pro Standard Efficiency Single Speed Up Rated Pool and Spa Pump, 1 HP, 115/230-Volt. $280.00
1 Sta-Rite P6RA6F-206L Max-E-Pro Standard Efficiency Single Speed Up Rated Pool and Spa Pump, 1HP, 115/230-Volt
$350.00
Ohhh. I would need it to start on low but only manual switch to high when needed.
How much extra does that cost?
$350.00
Thanks but looking for 2 speed
