Baking soda versus borax
Welcome to the forum.
Baking Soda = big TA change, small pH change
Borax = Big pH change, small TA change
Washing Soda = big pH change, big TA change. Probably more TA change than you want.
Depending on our conditions, it is best to get your TA to 50+, then use aeration to raise the pH. Chemically raising pH is rarely necessary.
Reactions: BMerrill
What is your current pH level? If it's 7.0 or higher, you really don't need to chemically increase it. Only if it's below 7.0 would I recommend chemically changing the pH level.
Reactions: BMerrill
Just a quick note on this. I love the way Borax makes my pool water feel! So I will usually use it to adjust pH, after getting the TA in range.
Question on this, I thought the test didn't really show below 7.0 very well? So if you are 7 you could actually be lower than that? Am I not remembering that correctly?
The block will show down to 6.8 I believe but stops at like 8.2 so can't tell if higher or lower than max - min of the test.
Thank you! I had my test run at a pool store so I could adjust. Ph was 6.6. T
Thank you! Your info was very helpful!
