- Jul 31, 2021
- 94
- Plaster
- Pentair Intellichlor IC-40
Just to give you a bit of backstory I've had my pool up and running for about 3 months now and the whole time I have been battling PH rising above 8 in short periods of time(checking every 2-3 days). All other test results were in a good range(TA: 80-90, Chlorine: 3-5, Calcium Hardness: 360) except for the CYA which had been really low(sub 20) I finally added stabilizer a few weeks ago and ran my pump overnight per the instructions on Pool School. It helped get my CYA up to 45, which i need to do again to get it over 60, but in the process my TA dropped to 30. I added baking soda 2 weeks ago and got it to 50. When i added it some settled on the bottom and i just brushed it off a few minutes later without any issues. I added more baking soda last week and immediately scrubbed the bottom. I got in the pool the next day and there were two white stains on the bottom where the baking soda settled. Has anyone ever seen this happen before? Any suggestions to clean it? I saw using an acid mixture could work but will spraying underwater even be an option. I haven't dove in and tried to scrub with a brush, which is going to be my first attempt but wanted to see if anyone on the board had experience with this problem before.
My readings seem to be in good order, minus raising the CYA a bit:
Chlorine: 7
PH: 7.6
TA: 80
Calcium: 360
Salt: 3600
Chlorine: 7
PH: 7.6
TA: 80
Calcium: 360
Salt: 3600
