Assemblymember Wilma Chan, 16th District, the author of Assembly Bill 1953 (Chan,Chapter 853, Stats. 2006), which codified the low lead requirements for plumbing
products, has published additional guidance about what she intended to be subject to
the low lead requirement. Based on the plain language of the statute, the legislative
history, and clarifying letter from Chan, the intent of the legislation is that the 0.25% lead
content requirement would not apply to devices that can reasonably be described as not
intended to convey or dispense water for human consumption. Such “exempt devices”
include:
• Service saddles
• Back-flow preventers which protect/separate potable water systems
from non-potable services such as irrigation, industrial and laboratory
use
• Water distribution Main Gate Valves that are two inches (2”) in diameter
and above
• Fire Hydrants
• Fittings and valves for Wastewater Distribution Systems
• Decorative Fountains
• Marine applications
• Air and Vacuum appliances
• Bathtubs and bathtub faucets
• Showers, bath and shower valves, shower heads of all types and shower head
adapters
• Roman Tubs and Roman Tub valves
• Sanitary Sewer Drains
• Irrigation Sprinklers
• Toilets, urinals, bidets and their fittings
• Faucets, fittings and fixtures for laboratory uses
• Utility, laundry and shampoo fittings
• Service sinks
• Whirlpools and Spa Therapy Pools
• Flexible plumbing connectors and flexible risers not intended for potable water
applications (e.g. clothes washing machines, dishwashers)
• Hose Bibbs, fittings, tees and splitters
• Flush valves
• Solenoid valves
• Pre-rinse Assemblies for commercial kitchen use, that do not include an
auxiliary spout or other outlet
