Hi folks,
My auto-fill device has stopped working reliably and I have some questions on how to repair/replace.
Context is this is on a new-to-me pool (as of July) so I don't know the history of this particular equipment..
Questions:
1. Can toilet fill valves be used for pool autofill, or are there pool-specific valves that should be used? I ask because my pool appears to be using a Kohler 1138930 fill valve (see photos), which says "Fluidmaster 400MODEL" on the float, which as far as I can tell is an ordinary toilet fill valve you get at the local home center and not a pool specific device. Further, there is a warning printed on the side "do not use chlorine (bleach) cleaners in tank water" which makes me think this device is ill suited for chlorinated pool water.
2. Can someone suggest what part I should buy to replace my existing fill valve? I'm 99% sure my device was originally a Poolmiser PM-101 (the lid, not shown, says "Poolmiser" and looks exactly like photos of the PM-101). Considering that, should I:
Questions:
- replace with same Kohler part I pulled out
- some other fill valve, if so, what?
