We're putting in a pool with an autocover. Our ground is really hard and everything seems to require the jackhammer. The pool builders expect the decking guys to deal with drainage. The decking guys appear to not want to trench a proper hole for the autocover drain to my French drain system as that would require them to dig a trench 2' feet deep about 50' long, so they are putting in a 2x2 gravel drain pit right next to the autocover to drain in. They think the autocover box isn't that big and shouldn't collect much water. However, I've been reading on here how a lot of water can get splashed over the damm wall.
Should I be concerned? They are going to start putting in the base and sand and then travertine in the next day or 2 so I need to decided now.
Not a great pic at night but that's the autocover drain with the red tape on it. I will say, our ground is bone dry here. They dug the pool down to 8.5' deep and no water to be seen. The pipe running over the top is tied into my French drain system.
