This is my first month maintaining my pool by myself so I'm on the learning curve. I'm assuming these are my anti-siphon and autofill valve valves. The autofill is leaking from the top where the red arrow is. While the autofill is threaded connections, the opposite end of the thread appears to be glued PVC. (But I've not tried to turn it with pliers yet.) My questions are:
1. Do I need to cut this this entire thing out?
2. Do you recommend any specific autofill valve or is this a Home Depot thing?
3. Should I replace the anti-siphon valve while I'm at it since it's likely quite old (maybe 10+ years), or if it ain't broke don't fix it?
thanks!
Mike
thanks!
Mike
